Has anyone used or using the align 100a esc cant find much about it looks a good price and i use align on most of my leccy helis as they are
easy to set up. Cheers
Assuming your talking about the new one available
I think I'm right in saying its a Hobbywing 100 amp V3.
If so it's a good ESC with a good BEC as well
Was looking at the hobbywing 100a esc they seem to have good reviews, there are a lot on ebay but are these the genuine product or a fake
product thats likely to fail.
I use the hobbywing version on my goblin 500, stick programmed it in 2 minutes and it's been faultless.
its true there have been fakes on eBay so I bought mine from raj at align for £6 extra, which isn't a lot for peace of mind.
Hi i have got myself the hobbywing 100a platinum v3 haven't programmed it yet but getting my head around the stick programming instructions .
i am used to the align esc which are very easy to program,I suppose it will be easier when i am actually doing it, got it from raj at align as dont
trust ebay ones that are available even though they are a lot cheaper. And you still get chinglish instructions.
Just a quick question,on my hobbywing 100a there are two plugs for the bec one goes to the throttle port n my vbar but where do i plug the other
one in an open port or does it need to be used at all. Thanks.
Be careful with the Mini V Bar where you stick supply, RXA is input ony. What Rx are you using if you're using speccy satellites then you can use RXC for the BEC supply
Thanks i am using a full size vbar with sats so i have three ports that i can plug it into, was just asking because all of the esc that i own only have one plug that plugs
into the throttle channel which supplies power to the servos as well.
