Right set-up is as follows
align trex 700
align ds615 on cylics
futaba s9254 on tail
savox sg 0351 throttle
align gp900 receiver and gyro unit with 2 speccy sats.
battery optipower 3650mah 2cell lipo (checked its fine)
ok i have all the above on my 700 i did have a brand new align 2 in 1 glow unit installed, on the first build set-up i hooked the battery up to the 2 in 1 via the red connector bonded the gp900 to my ds7s (new memory) then started moving servos it check reverse etc and noticed after both sats flashing. i double checked battery it was at 96% so rebooted both tx and gp900 all fine stable lights slowy moved servos everything fine but soon as i moved servos quickly i noticed servos stalling and gp900 rebooting and then flashing sats again.so rebooting tryed the rx battery off my 600 same results.so i ripped the 2 in 1 off my 600 and tried that one. SAME results WTF i was thinking so i then used a 4 cell nimh rx pack without the 2 in 1 unit ,not a problem no resettling or flashing sats.
after that i went and got myself a gryphon gvr-7020 reg hooked that up everything good. so using same battery as from the beginning i hook it up with a home made adaptor to use the smaller red connector same one as on align 2 in 1 (same cable as well) low and behold low batt alarm going off with servo movement i then rehooked same battery up using the xt60 connectors and all is good.
so the only thing i can think is the size of the cable on align 2 on 1 is only just up for the job and anything higher than stock servos rx etc the 2 in 1 fails ??????
has anyone got any insight to this ?????? what can be done about it ? if anything
thanks
gavin
align trex 700
thanks
gavin
