Has anyone done the fabled firmware update that was mentioned here before a couple years ago? All I can find are threads by a former forum member and I get an error message saying I don't have permission to view it or something, I assume those old threads are just deleted.
It was a Turnigy firmware you could load into the Hobbywing ESC for a much improved soft start (and possibly better gov, I'm not sure).
Mine is a HW 70HV.
I have two of these 70HVs and one has the updated firmware and works really well but I have no idea what firmware, what revision, how you go about flashing it or what hardware you need (obviously it takes some type of USB interface which I do not have).
Mine is a HW 70HV.
and a platinum star
. The soft start is now very smooth, no sudden kick at the beginning, the governor now works really well. My throttle settings are still a bit too low and I think this is because the output is coming from the Vortex and has been calibrated precisely for 100% each way, so using the settings I have on the other one is not giving me the same headspeeds. I will look again in the HW calculator for 10 poles and then get someone to tacho it for verification. What I find impressive though, is that it works really well even at quite low throttle (currently I was running at 69% in normal, 72.5 in idle-1 and 74 in idle-2 because that's what I have on the Hirobo but arguably it could be bumped up a bit as well). The motor and ESC stayed just a little warm, not hot at all (setup is Align 600mx / 510kv, settings are 8khz and timing is 11.25, governor high, in a Knight 600e with 600mm blades - headspeed around 2000 ish and prob should be running more like between 2100 and 2200.)
