3GX governor hunting / oscillating
  • 3GX governor hunting / oscillating
    The 3GX governor seems to be hunting for the correct headspeed. It's like is oscillating around the correct headspeed ie too fast then too slow but at a rapid rate.
    The setup is
    Trex 700N DFC 3GX v3
    TT redline 100 + 20% optifuel
    throttle servo HS 325 HB ( recommended by LHS even though its analogue)
    Lynx Clutch and liner
    Everything else is standard Align kit.
    BTW it's a new heli so new engine and probably not tuned optimally.
    I'm guessing there is some lag in the control loop due to the engine or the servo causing overshoot / undershoot of the engine speed.
    I have an old Vision 50 with s3152 cyclics S9254 tail and DS821 and revlock 10 for the throttle ( never gave any problems).
    So, I could poach a servo ( the voltage is 6V so rules out the S9254 without diode)
    Anyone had experience with the 3GX governor?
    Any good ?
    Blade 130x
    Goblin 500
    Trex 700N DFC Redline 100
    + Planes
    + HPI BAJA
    I don't have much experience with Nitro helis or the 3GX, so for a blind poke:
    How sure are you its the governor and not the engine causing the problem?
    Is that throttle servo fast enough to keep up - 0.19secs seems slow to me for governor control but as said - I'm not into nitro.
    Has adjusting the governors Gain & lag times made any difference to the problem?
    Matt
    Goblin 500 Sport
    Owner of
    One E.G.S.
