Servos - Trex 450XL
  • Servos - Trex 450XL
    Hi everyone.
    Can anyone recommend a set of decent servos for the above.
    I have a spare GY401 so a digital jobbie to go with that, and a set of cyclic & pitch servos.
    Need to be good but not bank-breaking.
    Thanks all,
    David
    Happy Landings.
    David
    Raptor 50. OS50
    Mcpx
    Blade 130x
    Goblin 500
    hitec 65mg's on swash are only real option these days and you have a few choices for the tail. i use a futaba 3153 (20 quid ish) with my gyro and i love it. you could get the new robbe 61 servo or if your willing to splash a little the 9257 is the one to get.
      I guess the output voltage on the ESC (Align RCS - BL25G) is 4.8v.
      If so, the 65mg look a good bet.
      But the spec on the 3153 seems to require 6v. Will it work on 4.8v or use a 3154?
      David
      Happy Landings.
      David
      Raptor 50. OS50
      Mcpx
      Blade 130x
      Goblin 500
        As long as you don't feed 6 volts into the 3154 - they certainly don't like it
        I don't know but would hazard a guess that the 3153 will run at 5 volts as well as 6 volts?
        | 3D Championship
          i'm running my 3153 at 6v but as rob said will work ok at 4.8-6v, your probably not wanting to run 3154's at 6v or they will fail rather quickly by all accounts.
            Cheers for that - 3153 it is then!
            David
            Happy Landings.
            David
            Raptor 50. OS50
            Mcpx
            Blade 130x
            Goblin 500
              I'm a noob with a Trex 450 SE V2 so no hard flying yet.
              I'm really happy with three Hitec HS-65MGs on the swash and a Robbe FS61 BB on the tail BUT the Robbe only handles 4.8V so I have an Align voltage dropper between it and the GY401. The rest of the electronics package is OK with 6V.
              Snarf
              Scale - Aerospatiale SA 315B Lama, Bell UH-1B Huey, Bell AH-1 Cobra, Bolkow BO-105, Hughes 500E
              Sport - Trex 450 SE V2
              JR DSX9 | Cellpro 10s | Phoenix
                I see there are some new Hitec Digitals in all the popular small sizes coming
                HS-5055MG
                HS-5056MG
                HS-5065MG
                HS-5082MG
                HS-5085MG
                So that will add some more choice into the pot
                Phil
                  just fyi, those servos are not available for 4-5 weeks.....i have them on order for the 500.
                    Hopefully get mine 1st as the importer is just round the corner from me
                    Phil
                      nice one...i've got the 5082's ordered.....17.50 each from my LHS.....not bad at all that.
                        David
                        So what voltage does the Align ESC fed to the servos/Rx?
                        If it's 4.8v then fine, but is it likely to be 6.0v?
                        Cheers all
                        Happy Landings.
                        David
                        Raptor 50. OS50
                        Mcpx
                        Blade 130x
                        Goblin 500
                          It's usually 5 volts.
                          | 3D Championship
                            are the hs-85mg servos for the cyclic ok on an esky belt cp?
                            whats better the 65mg or 85mg?
                            matty
                            Spektrum DX7s
                            DJI F450 naza/gps Trex 500
                              Hitec 65MG seem in short supply. Su**ex MC, Revolution Models & Midland are out of stock.
                              What else??
                              David
                              PS..fitted my spare 401 & a 3153 to the tail.....soooooo much better. Thanks for the advice
                              Happy Landings.
                              David
                              Raptor 50. OS50
                              Mcpx
                              Blade 130x
                              Goblin 500
