Align GP900 - Gyro/Gov - Calibration
  • Align GP900 - Gyro/Gov - Calibration
    Thought this might be a useful way to cut down on the wiring and tidy things up a bit.
    Only downside so far is the complete lack of any details about the Gov feature in the instructions ...
    Fast Lad are doing their bit to try and find out more information, but thought I'd check here just in case someone else has cracked it.
    Main missing element is calibrating the throttle, there doesn't seem to be any option for this.
    Clearly the unit is 3GX based and it enters the tail setup in the same way, but there doesn't seem to be a similar throttle calibration feature to the 3GX.
    Any thoughts or suggestions welcome
    All sorted now.
    Got to compare it with a 3GX today and it is in fact exactly the same calibration routine.
    The only trick is don't get distracted by the fact that the unit resets faster than you'd expect. It doesn't wait for the throttle to hit 100%, so just go for it and it does work as tested today on the 3GX
