How do you choose servos?
  • How do you choose servos?
    OK so I'm thinking ahead to getting my Phoenixtech 700e once Andy gets the nod on the test flight the pre-production one is getting.
    I'm going electric, made that desicion now so now I'm on to choosing the electronics, servo research now.
    I'll be using MKS servos but there's a huge range of different types.
    Now I'm really more interested in F3C style controlled flying right now ( I'll deal with this stick wanging stuff in the future I'm sure ) and I was told to go with the DS660A servos because they are more F3C orientated.
    But why is one servo better for F3C over another, and why would something else be better for 3D?
    At the minute it probably doesn't matter what I get as my 'flying' is so basic anyway mostly hovering, so I could get away with pretty much anything I guess. But I like to understand this stuff
    Lynx Heli Team Pilot
    Hi Pete,
    I would think for F3C you require a servo with precise centering,hhere as for 3D grunt plus speed,but let the big boy's come along and explain better,as I could be wrong.
    Yours,
    Marty.
    Chase 360 and JR Ninja all controlled by JR XG8
    proud owner of 2 EGS's
      The ds670's centre perfect, using them in my trex 700 at the moment, superb servos
      James
      Sponsored by
      Align-Trex.co.uk
      Optifuel/optipower
      MKS servotech
        Thats it.
        3D servos are quicker whereas F3C servos are not needed to be as quick but F3C servos have more torque than the 3D servos
        Take a look at Futaba BLS252 (F3C servo) and the BLS 253 (3D servo) for a quick comparison
        Midland Helicopters Ltd RadioAccs_Servos
        But tbh I have used both and cant tell no difference at my level between them
          Just got some ds670 and feel nice also got a gob load of torque,
          Sent from my iPhonings
          Oxy4+, tgy servos, hw60a, spirit fbl on 6s 🤓
          sigpic - Team pilot
            cant wait to get hold of that thing!
            i use JR DS8231, they centre well, got ok torque and are real smooth! in the rappy
            Chris 'CHUNK' Newby
            ALIGN-TREX.CO.UK team pilot
            LYNX team pilot
            SPARTAN team pilot
            Dx18
              im using outrage torqe servos they are very good center well and very strong
                and they are £100 each
                Chris 'CHUNK' Newby
                LYNX team pilot
                SPARTAN team pilot
                Dx18
                  I go to www.google.com and type in "ALIGN DS610 Servo"
                  Like so:
                  Click me
                  In all seriousness, I go off speed and torque ratings, without breaking the bank. I tend to favour the 610s as they are good value for money. For cyclics, you need torque over speed, whereas tail it's the opposite.
                  Harry
                  Powered by Futaba 18SZ
                    TBH Harry's right here, the 610s are a very good servo for 3D and F3C
                    Chris 'CHUNK' Newby
                    LYNX team pilot
                    SPARTAN team pilot
                    Dx18
                      Any Futaba BLS, or the Outrage servos are top banana..
                      x 3
                        What I'm hearing is that people just stick with what they know, and don't specifically pick servos other than picking the fastest and highest torque in the budget they have. But what I mean is how do you pick between which of the two you want?
                        The DS660A have much higher torque, but less speed, than others, or even the Aligns.
                        Dead band: 0.001ms (Default)
                        Control System:
                        +Pulse Width Control
                        Working frequence: 1520μs / 333hz (RX)
                        Required Pulse:
                        3.0 ~ 5.0 Volt Peak to Peak Square Wave
                        Operating Voltage:
                        4.8 ~ 6.0 V DC Volts
                        Operating Temperature Range:
                        -10 to + 60 Degree C
                        Operating Speed (4.8V):
                        0.186 sec/60° degrees at no load
                        Operating Speed (6.0V):
                        0.149 sec/60° degrees at no load
                        Stall Torque (4.8V):
                        21.05 kg.cm (292.4 oz/in)
                        Stall Torque (6.0V):
                        26.30 kg.cm (365.3 oz/in)
                        360° Modifiable:
                        NO
                        Motor Type:
                        Coreless Motor
                        Potentiometer Drive:
                        Direct Drive
                        Bearing Type:
                        Dual Ball Bearings
                        Gear Type:
                        Metal Gears
                        Programmable: NO
                        Connector Wire Length:
                        15.0 cm (5.9 in)
                        Dimensions:
                        40 x 20 x 40 mm
                        Weight:
                        75 g
                        They don't break the bank or anything either.
                          Control System:+Pulse Width Control
                          Required Pulse:3.0 ~ 5.0 Volt Peak to Peak Square Wave
                          Operating Voltage: 4.8 ~ 6.0 V DC Volts
                          Operating Temperature Range:-10 to + 60 Degree C
                          Operating Speed (4.8V): 0.186 sec/60° degrees at no load
                          Operating Speed (6.0V): 0.149 sec/60° degrees at no load
                          Stall Torque (4.8V): 21.05 kg.cm (292.4 oz/in)
                          Stall Torque (6.0V):26.30 kg.cm (365.3 oz/in)
                          360° Modifiable: NO
                          Motor Type: Coreless Motor
                          Potentiometer Drive:Direct Drive
                          Bearing Type: Dual Ball Bearings
                          Gear Type: Metal Gears
                          Programmable: NO
                          Connector Wire Length:15.0 cm (5.9 in)
                          Dimensions:40 x 20 x 40 mm
                          Weight: 75 g
                          things like i have highlighted are normally what i look at!
                          they look pretty good specs mate
                          Chris 'CHUNK' Newby
                          LYNX team pilot
                          SPARTAN team pilot
                          Dx18
                            I got the Align Servos in my 600 as part of the combo but if i was going to buy servo's now i would porbably just take the recommendations of the 3D pilots in our club (there is a few ) and get them.
                            Del
                            Climb-Out
                            3D Scotland
                            Proud owner of 2 EGS
                              That works if you only want the opinion of 3D pilots
