I thought people ran the rx and cyclics at 6v and the taila t 5V and so fed a 6v signal to to a servo running at 5V. I want to run the rx at 8V and the servos at 5V or 6V off the bec and just connect the signal wires. If it is a problem then I'll put voltage level changers in. The power distribution system isn't very good really with the standard servo connectors.
I don't know the uptodate way of level changing. I'd use a couple of transistors. Perhaps someone like micron sells something.
If so I'd have thought it was easier to just wire the voltage sensor into the battery connector on the ESC so it reads the direct input voltage from the Lipo then use the ESC Bec for the rest.
