Phoenixtech GT9 Gyro
  • Phoenixtech GT9 Gyro
    Hello all,
    For the Phoenix GT9 gyro, Iam having problems with the tail servo binding in one direction.. i have tried multiple times to set the limits within the gyro, but when I go back. it keeps on binding in the same direction.. Any ideas? Thanks!
    Best bet is to speak to Andy at Phoenixtechuk. I'm sure he'll be able to advise.
    RCHA Member
    LFXproductions.co.uk
      Quick question... on the Phoenixtech ESC there is a plastic shrink wrap.. do i need to remove this prior to installation?
        hi
        you must exit the menu before you switch off,after setting the end point hold the rudder stick for at least 3 seconds to exit the menu.or it wont store the setting.
        im sure this is correct but i will check today myself and hope this helps.
        As for the speed control,leave the shrink rap on
        cheers stefan/craig
