Savox 1350 servo gears?
  • Savox 1350 servo gears?
    Anyone know anybody who has stock?
    My LHS sells the servos but has no gears and the gears are on back order at CML apparently
    I'm just wondering if the ones from the DS510 are the same now as they are supposed to come from the same factory and the spec is almost identical?
    Phil
    Yes Savox make Align servo's most gear sets will fit.
    but I haven't done it so will not say 100%.
    how do you find them other then the gearset?
    I like mine very much feel better then Align so bit's might be different.
    Cheers Paul
    Citizen #42
      I like them! I have 510s on my Atom and the Savox on my FBL T Rex 500 both work ok but machines are quite different to fairly compare in my opinion!
      Phil
        I can state that 510 gearsets fit Savox 1350's 100%
        Phil
