Futaba S9254
  • Futaba S9254
    Hi, I have Futaba S9254 on the tail rotor of my V1Raptor. The linkage got jammed, which stalled the servo briefly and it got warm, do you think I will have done any damage? It seems to be working ok, will this be alright or does it need to be checked out proffesionally, if so where would I send it?
    I am also trying to set up Futaba GY520 gyro. When using in avcs mode; switching on the servo centalisers; but after using rudder stick, it does not centralise completely. I have not attempted to fly it as yet as I am not sure if this is correct. Can you tell me if this is normal and offer any further advice?
    geebee
    i'm sure the servo will be fine as long as it was only warm when gyros are in heading hold they wont centre until the heli has turned the amount requested when you moved the stick this i totally normal. if you flick it into rate mode it will self centre when you let go of the stick
