Will a spectrum gov sender work on total g ?
  • Will a spectrum gov sender work on total g ?
    As above really, I can't find a side frame mount so will the spectrum bottom plate sender work? Cheers tom
    Yes from what I've read the Spektrum backplate sensor works perfectly with the Total G.
      hi yes it will
      Hope that helps
      x Rachel
        Thanks for clarifying that Rachel, I've just bought a Total G as well so I'd better order a spektrum sensor as well then.
          not tried it myself
          But,....
          I am sure its on the detailed instruction FAQ's
          I wish I had known when I made my ENV gov sensor mount , it took ages
          I love my Total G on my friends Rex 500 esp it was amaizing made me want to nick it back and put it back on the ENV
            My Total G is sitting in it's box just waiting to installed but apparently
            I've got to wait until my bday next month, ummmm we'll
            see about that!! :-)
              I'm using the Spektrum backplate sensor on my totalg and it seems to be working ok.
              I do have an issue with overspeeding when the head unloads, but this could be down to the engine still running a little rich, although someone on allMYrc has posted the same issue running the Spektrum sensor.
