BLS 251 and 8900G
  • BLS 251 and 8900G
    I'm looking for a new tail servo for my 700, decided that it will be either a Futaba BLS251 or a JR 8900G.
    I have used JR in the past, so I think I am moving towards this one, but heard alot of good reports about the BLS251.
    Does anyone have any good or bad experiences with either of these servos that are worth considering before I hand my cash over, or is it really all down to personal preference?
    Steve
    Logo 500SE
    Forza 450
    I have a Futaba 9256 for sale Steve if you're interested in one of those, you can have it for £45 delivered, PM me if you're interested but in answer to your question i have both the above mentioned servo's on my heli's and never had any issues with either
    www.captaincrash.co.uk - Carbon Blades, Carbon Upgrades and Optifuel Products and Fuel
      I have BLS251's on three models and all are fine no problems there at all...
      Steve
      Steve...
      Outrage RC Field Rep
        I have an 8900 but it doesnt like 6v
        x 3
          Both great servos. Either will do fine.
          I prefer JR so went with the 8900G over the Futaba Brushless but they fly equally as well.
          Top pilots run both.
            I have both and like both.
            The BLS is brushless so that may be an advantage due to the longevity that will give over non Br.
            JR have a new Brushless tail servo coming MP80G its more expensive though.
            Like Sacko said the 8900g don't like 6V.
            They are both top notch
              Had an 8900G go bad, JR said it was badly mounted & damaged the pot??? how can i damage it by putting it in the tail servo location??? I have a BLS 254 now & it's great. So i'd go with the BLS as i've also heard of other reports of 8900's going bad
                Used the 251, 8900 and 9256.
                Could not tell a difference between any as they all great servos. Use 251, 254 and 9256 now.
                  Originally posted by sacko View Post
                  251
                  Will a BLS 251 run on more than 4.8v then. I thought they were limited to 4.8v like the JR 8900G.
                  I've ordered a BLS 251, but it has occured to me that my BEC is (I think) set to output 5.6v, so I probably need to step that down for the 251. I have an Align step down, but I think that is designed to step down from 6v rather than 5.6v, so I'm not sure if I use that on 5.6v is the final voltage actually going to be too low for the 251?
                  Maybe it is not an issue and the 251 will be fine at 5.6v, but don't want to wreck a shiney new BLS servo so any thoughts appreciated.
                  Steve
                  Logo 500SE
                  Forza 450
                    I personally have seen a bls running on 5.8v (from a 2 in 1) for hundreds of flights with no ill effect and its still going.
                    a fully charged nicad/nimh is over 5.6v when full.
                    You make the choice though.
                      Available now (just had mine delivered) and yes they are expensive but hey its only money
                      Took a BLS251 off the Vibe SG in order to fit the MP80G as I was having some issues getting the gain on my CSM720 within limits.
                      I will let you know the results in a week or so when I have fitted it and tested (away all weekend)
                      TDR (in progress)
                      SAB Goblin 700
                      Vibe 90SG Vibe 500E
                      Kalt Baron30
