Solid G Reset?
  • Solid G Reset?
    How the hell do you reset these things to factory? I've made some edits to test the reset but it just isnt working for me??
    Press and hold both the 'L' & 'H' buttons while switching on RX.
    This will reset the whole lot.
    Ian
    Knight 3D
    Velocity 50
      Either:
      select a new heli
      or
      Hold down "L" & "H" buttons while switching on the receiver
      Chugga beat me to it
        Cheers guy's, however, I have tried the L and H buttons and everytime I go back in on the G view the settings have not defaulted back. ??
          Select a new heli setup in the menu.
          The L + H should work
            What settings are you expecting to change Tom, and to what?
            There isn't a list of settings for each model memory in the manual, so unless you'd made a note of them, how would you know what 'Default' is?
            Ian
            Knight 3D
            Velocity 50
              I'm expecting things that I went in and purposely changed to go to another value ie. their default value. I have messed so much with the other models that I really need to reset the whole thing.
                I. To Reset - Hold down both "L" and "H" buttons while
                switching on the receiver...
                This resets all models to default.
                2. "Push and hold "P" about 6 seconds". The 6 seconds
                does vary a little depending on the radio being used. It
                could be as little as 5 seconds or as long as I 0 seconds.
                3. When turning on the gyro, the LED turns green, wait 5
                seconds for the gyro to initialize before moving the
                helicopter, then LED turns off. If the LED stays on
                Red, there is no TR signal. Check your radio and
                installation.
                4. The unit will exit a menu after about 30 seconds when
                no buttons have been pushed.
                http://www.rcheliaddict.co.uk/galler...LID_G_GYRO.PDF
                www.evorc.com
                Beam E4 Specialists with a complete stock.
                Synergy, Rave, Align, ElyQ We stock kits, spares and SE upgrades.
                See web for many other top brands.
                Feel free to call just for a chat.
                  Am i to take it that the setup consists of the following: (with a G-View)
                  Setup Menu = Set limits, direction and neutral
                  Model Menu = Choose a model?? I guess you choose a similar model and this loads a template of parameter's on the higher menu's of settings??
                  Pirouette Menu = Loaded from model selection above?
                  Response Menu = As Pirouette Menu?
                  Parameter Menu = As Pirouette Menu?
                  So, should a reset, reset all your limits and directions, along with all the menu items above the model select menu???
                  I hope they write a better manual for the Total G
                    installation.
                    straight from the manual!
                    I have seen that Rob, and I am guessing that only point 1 refer's to the resetting of the gyro. The rest on that page is general information, pretty confusing if you ask me
                      I've never actually tried to reset one Tom, but maybe try holding the buttons for longer when switching on? Let the gyro initialise fully before letting go? Only a guess mate. Like I say I've never done it myself.
                      Ian
                      Knight 3D
                      Velocity 50
                        It's pretty simple Tom
                        1. Remove Solid G.
                        2. Fit CSM 720
                        | 3D Championship
                          I've got the manual in front of me Rob, and I can't find that bit anywhere!
                          Ian
                          Knight 3D
                          Velocity 50
