Hello all,
I'm a bit in a dot with TJ RevMax and DX6i setup.
I can think of three ways of setting it up, which one will be better or maybe you have some other hints:
Throttle curve linear from 0 to 100.
1.
Travel adjust for throttle channel +100 up means full throttle up on the engine.
Travel adjust +100 down means engine stop - marks on engine throttle arm are pointing each other >< .
Trim 0
So I calibrate TJ with this settings, but I will have to use throttle curve to adjust engine idle.
2.
Travel adjust +100 down means engine at idle
Trim 0
Then I don't have to bother about throttle curve - lowest point of curve means engine at idle, but TJ does not see full range of servo movement.
3.
Travel adjust +100 down means engine at idle.
Now I will use trim down to show TJ minimum servo position, but if I calibrate TJ this way I will move all servo movement down to I will miss top 20% of servo movement, right?
Or should I start calibration:
a) trim down throttle stick down
b) move trim to neutral and throttle stick up
c) trim down and stick down
I really don't want to use gear channel for TJ.
Thank you for your help.
Kind Regards,
Michal
1.
Trim 0
2.
Trim 0
3.
Kind Regards,
Michal
