multigov pro and avant fan.
  • multigov pro and avant fan.
    Hi,
    im going to be fitting the multigov to my avant.
    the fan on the avant has only one hole for a magnet.
    does it matter which way i put the magnet?
    cheers Jon
    Jonathan
    trex 600
    Trex 450 v2
    and an
    It depends on the sensor. The manual should tell you, if not wire it up and test it then mark the magnet with a pen so you know what way to fit it.
    Cheers Adam
    Volatilis vacuus alai
    Owner of an "Evil Gold Star"
      If it's the same as the eMultigov (which I suspect it is) then yes it needs to be a certain way so do as ddracer suggests and mark it.
      Mikes Place - Home of the golden dump.
      Sponsored by Elite Models.
      http://www.elitemodelsonline.co.uk/
        The instructions will tell you to let the magnets attract, mark the attracting faces [ ie N and S ] and then put the marked faces upwards on the fan facing the path of the sensor. When you switch it all on, and rotate the fan, one of the N or S faces will trigger the sensor. This is when you install both magnets.
        In your case, power up the sensor, mark one side of the magnet with a red pen, and see which side triggers the sensor.
        Mike
        TRex 600NSP, OS55, MicroBeast
        TRex 500ESP
        Futaba 14SG Optifuel 20%
          Hey Jon,
          On another point, I believe you will be using a YS in your Aurora? If so I would suggest setting the "low throttle percentage" to 25. The default settings are a little high for a YS
