Align Governor
  • Align Governor
    Hi Guys
    In the process of fitting an Align RCE-G600 Governor to my Raptor 50. What is the recommended sensor to magnet distance?
    Terry
    Raptor 50 v2 - OS 50 Hyper - Spartan Quark - DS 650 - DX7
    Raptor 50 Titan SE - Redline 53 - Spartan DS 760 - DS 650
    Mini Titan e325 - Spartan DS 760 - 6100e - Huey Fus
    Phoenix
    Holder of 2 EGS
    Need a DJ? www.soundmachinedisco.co.uk
    As close as you can get realy terry
    I would say about 1mm to 2mm will be ideal.
    when youve set it turn the system on & rotate the fan.
    There is a light on the unit when the magnet laps over the sensor
    it will turn the light out. if it doesnt do this its not sencing correctly
    or one of your mgnets is in the wrong way.
    Martin
    Aka RCSlopesurfer
      I set mine about 1 to 2mm. How di you do the mounting bracket?
      Cheers Adam
      Volatilis vacuus alai
      Owner of an "Evil Gold Star"
        Unless your unit works differently a guy at MK tried to use the sensor on a raptor and it didn't work. When fitted to a T-Rex the "sensitive" side of the sensor is the writing which faces the magnet. In your Raptor it will be fitted so the underside is facing the magnet and for this guy it did not work.
        Member of Mk Heli Club
          During the setup process the unit will work as per the instructions. When the fan is turning at 17,000 rpm the sensor does not "see" the magnet properly and so the governor does not work.
            Thanks guys...I found a thread on helifreak describing the method.
            My setup for Align Governor on Raptor Titan 50 - HeliFreak
            I used a piece of carbon tail fin for mine.
            Terry
            Phoenix
            Holder of 2 EGS
              Gah not good then.
              Maybe needs a revlock ten?
              I didnt know this to be a problem on
              the raptor.
              Martin
              Aka RCSlopesurfer
                Worked fine on my Titan and I'm running 1950rpm. I will update this post in a bit with a pic of what i did.
                Ok not on the titan but the compass (****ing down out side so cant be arse to get it) But it is the same on both only the length is different. By offsetting the sensor it put the magnet dead center. I keyed up the aluminum and the sensor board then epoxied the board to the plate. Then lockwired it and epoxied over that.
                Cheers Adam
                  The Guy on the other forum claims it worked for his Titan too....shall be interesting to see
                  Looking forward to the pics
                  Phoenix
                  Holder of 2 EGS
                    There you go.
                    Cheers Adam
                      Thanks....very helpfull
                      Terry
                      Phoenix
                      Holder of 2 EGS
                        What do the magnets actualy do, been searching but to no avail.
                          The sensor is a Hall effect sensor. All it does is give 1 pulse per revolution of the engine. The two magnets are set one north the other south. The sensor only read north so you only get one pulse. The other magnet is only for balence on the fan.
                          Cheers Adam
                            Hall effect sensor - Wikipedia, the free encyclopedia
                            Cheers Adam
                              cheers, I did check heli wiki but didnt know what is was properly called.
