GY501 - DX6i Setup
  • GY501 - DX6i Setup
    Hi Guys and Gals,
    Just a quickie in normal mode for people that have dx6i's what do u have ur tx gain set at NOR mode only.
    Jonny
    Same as in any other flight mode, your better using the gyro sense menu setting it for hh and leaving it alone, you really only need one gain setting as on the dx6 you only have 1 idle up so 1 higher headspeed.
    Alex
    Innovation RC Blog
    Innovation-Rc on eBay
    www.heliharry.co.uk
    www.robochallenge.co.uk
    500 ESP. Ely Q Comp, KASAMA'd 600
      to be honest i have only ever flown in normal mode never heading hold mode, however the gyro is set to normal and on my dx6i i have set gain to 40% and still doesnt hold tail brilliantly hav only just found out u can see what it is set on on gyro at the same time so i will have a look at that
      thanks
        thanks
        AFAIK, anything under 50% gain on the TX is rate mode, I would try to up your gain to over 50%, this said I have no experience with a GY501.
        Sean
        Retired
