Problem with MultigovPro ?
  • Problem with MultigovPro ?
    I have been running this gov for ages, must be a good year and a bit I would think..... no probs until last flight of today when the blades stopped twice in flight when I came out of a roll.
    I thought it was an engine tuning issue, but coincidently I was showing the display on the MGP straight after and I noticed it wouldnt go in to govener mode and wasnt seeing the sensor either under sensor test.
    When I plugged the MGP display in, the gov wasnt enabling, but the speed1/2/3 was switching in the flight modes and the throttle was moving. No lost magnets and sensor is working fine now I have got home and tried it out properly.
    Strangly though.... if I put the throttle at zero, the gov would enable and if I put it above the low cut off or switched in to idle it was saying gov = OFF!
    I was going to totaly reset the govenor but decided to check the throttle idle and high points... upon which I discovered they werent moving the servo..
    I re-did the idle and full throttle end points on the gov and it seems to be working again, no idea what went wrong. If I now select a different flight mode, the MGP display shows the gov = ON (as it used to).
    I have test flown in the garden and it seems to be OK now.
    Anyone else had a similar experiance or any other ideas?
    FYI, just in case it matters...
    SPEED1 = OFF
    SPEED2 = 1750 3D
    SPEED3 = 1900 3D
    Engine = OS91HZ
    Low throttle = 40%
    Regards,
    Jason
