4 Pin Servo Lead?
  • 4 Pin Servo Lead?
    Hi all,
    I'm trying to find a 4-Way Servo lead/connector for a project, and cannot find one anywhere (probably because i don't know what they're called).
    I know they exist because my Helicommand uses one for starters, I just cannot locate them to buy...
    Any help very much welcomed!
    Trex 450 V3
    You will have to make it I expect. Depends when you need it I could probably get my Dad to make you one up if you give me the spec.
    Welcome to rswww.com
    Cheers Adam
    Volatilis vacuus alai
    Owner of an "Evil Gold Star"
      Plugs are available here to make up your own leads.
      Universal 1 X 4 Plug for Standard Servo Pins Set of 10
      Its a US site but if you can`t find them in the UK it shouldn`t be a problem.
      Blade mCPX - now Version 2
        I will ask a mate tomorrow but they are definately available in single pin up to many as they are used in PC's etc as well as for servo plugs. RS and the like should stock them... molex probably make them but you would need to check.
        I will post back here tomorrow if I find out a source for you
        Futaba 9CP & 10CG
          Yes Molex make the plug as you say they are used in the electronics world alot. To do the end right you need a special rachet crimp tool and thay are not cheep.
          Cheers Adam
