Savox SH-0257 servo issue
  • Savox SH-0257 servo issue
    Savox servo issue:
    My multiplex is now up graded to 2.4 this runs at two speeds 21ms & 14ms (same as normal futaba) but is 12bit 3872 resolution. Can I notice the difference? Sure brain and fingers hard wired! No at 44 I’m too old and slow however it does have that connected feeling and the servos (multiplex & Hitec) are fast and very very smooth. Unlike the savox servos I have, which can’t cope with the speed & frame rate, they lock out and run poorly unless the speed is reduced 21ms. No doubt some of you technically able chaps may be able to explain this to me. I thought as they were digital they should cope, my multiplex & futaba analogue servos are fine with this system. Anyone else have this problem with SH 0257 servos at high frame rates?
    As a note both Multiplex and CML are being very helpful in investigating this and have sent a servo for testing.
    F.arch
    Yes, it's an old thread but I have the same Tx and would like the answer. There is no info on the CML site. Standard rates will do but digital should be higher and suitable for flybarless.
    Blade 130-X, MSR, MSRX
    Phoenix Sim
