Hi
I have tried to set up my Align GP750 gyro today and have one problem that I need help with.
When setting the travel limit using a 7C radio with a DS620 servo I can not get full travel. I have set the end points to 100%. Centred the servo in rate mode and centred the tail slider to its zero position. I then enter the limit menu and push the stick left until the limit is reached in the out position, then right stick which stops approx 10mm away from the gearbox housing and will not go any further.
With these setting saved, when moving the stick, all the servo travel is taken up in the first quarter of stick movement in both directions which is going to make this very sensitive to inputs.
Does anyone know how to achieve full travel and also how to set full travel on the stick to equal full movement of the servo throw?
x 3
