Spartan question
    Originally posted by scallybert View Post
    Fair enough.
    In normal mode, the rudder input just corresponds to a rudder offset. This might not even be noticable in flight, as it could correspond to a mechanical offset/error.
    OTOH, a rudder input in HH mode (with the model static) causes an increasing/decreasing tail pitch.
    your spot on. thats all normal mode does. since this is only doing it in HH mode i can only ASSUME it's not the gyro seeing a rudder input.
      Just checked it with a (hopefully...) correctly set-up DS760. (And a BuzzFlyer gyro.)
      Power up on bench. Both normal & HH mode leave tail at 'neutral' pitch.
      Switch to normal. Apply rudder trim. Tail pitch increases with trim. (1)
      Switch to HH. Tail moves to extreme - speed determined by amount of trim.
      Switch back to normal. Tail flicks back to (1).
      Switch to HH. Tail moves to extreme, as above.
      Yes, it's th@ tw@ Scallyb@...
