Align 610 servos
  • Align 610 servos
    Will thease servos take 7.4V?
    Trex 700n DFC.
    Trex 700e TOP.
    Trex 700e Pro.
    Trex 600n DFC.
    Vbar Controller.
    Yes indeed Arwel.
    As with the JR8915s your warranty is invalid using this voltage though.
      ...but if you but the same JR servo in a fancy case and pay ££££ then there is a warranty on 7.4v (actually 8.4 when the 2s lipo is fully charged).
      If you are concerned about over volting your swash servos running direct off the lipo one way is to only charge your lipos to 80% with a charger that balances during the charge not just at the end of the charge (guess which make of charger will do that ).
      I'm quite interested in running the swash and rx direct off the lipo as this might make the heli saveable after a total regulator failure (given luck and skill).
      ....whos going to try a DS620 on the tail direct off a 2 cell lipo? A CSM720 will take the voltage I'm told!
