Evening all,
Looking for a little bit of help please.
Having set up the governor as per instructions,everything seems to work properly, the magnet makes the led go on and off,the switch im using(gear sw) switches it on and off,set the min and max throttle end points,
ATV SET +100% -100%
tHROTTLE CURVE LINEAR 0-100%
but even with the stick at bottom with the switch on the governor is still showing a green led, thought it would go red until 30% was reached then go green.
Have gone throught the set up several times and still have the same result.
Any help would be appreciated.
Cheers Gaz
ATV SET +100% -100%
Cheers Gaz
