If I purchased an after market multi blade head for my 450, would I need to go flybarless?
Flybarless multi blade?
Fast lad do a number of multi blade systems with included flybarless kit:
http://www.fast-lad.co.uk/store/inde...cc941040f837a7
Might be worth looking atTrex 500 with Co-Pilot 2 : Blade 400 (about to be sold) : Gaui Flybarless unit (about to be sold) : Blade MCX : Phoenix & owner of an Eddie Gold Star!
If you've had fun playing with helis' wait until you've seen some fish swimming! Wooo Haa!
Check out http://www.fish-cam.co.uk if you fancy!
There not too bad a price, I was expecting them to be alot more expensive!Originally posted by billytkid View PostFast lad do a number of multi blade systems with included flybarless kit:
Although the multi heads are for 3mm shafts, I'm not sure but think the 450 is 5mm, but could be wrong.Trex 450x CDE
MFA 500 Sport
MS Hornet CP
Twister CP Gold
Blade mcx
Hi there, the 3mm heads are for gaui's etc.... We do a number of 5mm ones for the t-rex etc here..
http://www.fast-lad.co.uk/store/adva...+blade&x=0&y=0
Chris
Fast Lad Performance
www.fast-lad.co.uk
Having tried this, the biggest recommendation i can make is to ensure you have the collar that goes from the swash to the main shaft in exactly the right spot. A couple of mm either way will cause you no end of problems. its called percession. With my 5 blade head on a 450 this was done by moving the collar until the blade parallel to the boom did not move when cyclic was applied. Even when set, it was a real handful to fly!
You have to get the headspeed right too. Cant remember which way, but i think if you have a lot of head speed it makes it easer to hover, however you will loose tail authority... and that can really catch you out as it did me.
If you are really serious about getting this to fly well, then look at some of the already mentioned flybarless systems already on the market. It will effectively put gyro stability on the aileron and elevator for you and make it much easier to fly.
Rgds
Aidi
Cheers for that, I'm going to go with a four blade head, and the flybarless system fastlads recomended in my other post.Originally posted by Aidi View PostHaving tried this, the biggest recommendation i can make is to ensure you have the collar that goes from the swash to the main shaft in exactly the right spot. A couple of mm either way will cause you no end of problems. its called percession. With my 5 blade head on a 450 this was done by moving the collar until the blade parallel to the boom did not move when cyclic was applied. Even when set, it was a real handful to fly!
Rgds
AidiTrex 450x CDE
MFA 500 Sport
MS Hornet CP
Twister CP Gold
Blade mcx
