Trex 700 with align governor install
  • Trex 700 with align governor install
    Hi can anyone help me with pix please of how and where you put everything?
    J
    If you do a search on Google for Trex 700 Build Log, there are 100's of example of where people have placed their electronics and routed the cables.
    700N 700E 550E
      If your using the Align governor that comes with the 700, its got a bracket on it and a purpose made mounting for it.
      If like me youve using revlock then your gonna have to make a bracket that turns the sensor 90 degrees for it to read the magnet.
      All the best
      Tony.
        Well the manual shuold cover how to mount the governor sensor, use the one from the kit box not from the governor box.
        As for where you put the governor itself thats up to you, mines mounted upside down under the Rx.
        If you mean electronics in general check out this thread over on helifreak, lots of pictures of peoples wiring from neat to birds nest
        http://www.helifreak.com/showthread.php?t=84657
