I am fitting some new Futatba servos to my T rex 600, the new servos have been supplied with some rubber grommets, but the extra padding means that my screws are a little short. Must the grommets be used or can i fit the servos without the grommets.
Servo Grommets
You can but i would advise to use the grommets supplied as the grommets give the desired movement / give the servo needs.......best to use slightly longer screws.T3ds Gy240 S3153 with trex500 skids and trex500 fin set plus now with hybridized canopy and Mini Titan canopy body post set P# PV0816.........Now owned by MoJo have fun
