I have just installed a Sonix 80a ESC on a new build 3dx and after setting up its program ie Brake, battery type etc and giving the heli a static test run, I changed my mind about one of the settings but find it will not re-enter the program mode again. I have carried out the program entry mode to the letter but all I get is the normal start up mode proceedure.
Can anyone confirm whether I should or should not be able to re-program the esc, as I cannot believe they are only programmable once. The ESC manual does not say either way but I would be grateful to know the answer before I send it back to the supplier.
compatible.
Thank you.
