Help please, Futaba S3152 servo gear set replacement.
Could someone please help, need to replace the gear set in a futaba S3152 servo. Question is, how do you get the bearing off the main black gear without damaging the bearing.
Trex 600 NSP and as my first proper Heli, I'm loving it.
stanley blade... put it between the bearing and gear and work it off slowly a bit at a time turning the gear round as you go. Be careful not to put too much force or ya could snap the blade, just loosen it until theres a big enough gap then put a flat blade screwdriver in and repeat. Just make sure you turn it a bit at a time until it slides off or you'll damage them. Shouldnt be too hard to be honest. I done one not too long ago.
Lee
