Hi Guys, after getting my CSM420 to work pretty well and then deciding that its a bit old hat and a newer shiny 720 is the way forward, I've just been over the field only to find the 720 not working at all well.
It takes off ok, but within seconds its doing a wag that can only be described as self destruction, swinging 45 deg left and right. It calms down a bit in rate but its clear that something is very wrong. The mechnical setup should be fine as its not changed since the 420 was on and that worked ok.
I think its only settings so any ideas ?
I've tried gain values for both rate and HH of 50 to 130 but its clear that it just gets worse the higher the gain.
The only other thing is mounting. Vibration filter is off, and its mounted on a single CSM pad, metal plate and then hard mounted to that with very thin double sided tape. If there were problems in this area i would have expected drift rather then a violent wag.
Any help would be much appreciated. Failing advice here its gonna be a call into Dr TrevB and a cheeky trip to the Hayling field.
so that the tail blades were acting with the wash from the main blades, not against.
