I'm in the process of setting up my first ATGV3 and whilst I know I have a damaged sensor (I've just snapped one of the leads off ttrying to do an electrical check on the sires...doh), I'm not sure whether the ATGV3 is also broken.
My Savox 2275 works fine when plugged directly into my Bavarian Demon 3SX, but does not move at all when plugged into my ATGV3 (I have set the transmitter low & high points, and had got to the stage of testing the sensor but could not get a red indicator light even when passing a magnet over the sensor with it removed from the airframe).
My questions;
Should the throttle servo move when the engine is not running? Or does the ATGV3 not send a signal to the servo if the sensor is not detecting the engine running?
Regards
Ian
My questions;
Regards
Ian
and a platinum star
