kola k bar gyro
  • kola k bar gyro
    Having issues with my gyro direction. I've set the mounting position as it is on the Heli but the tail is still moving in the wrong direction. Servo direction Is fine right input tail leading edge left etc but move nose to the left and leading edge goes right. Can't find anything in the vstabi to change the gyro direction. Any one had this problem or know how to change the direction please. Any advice would be greatly appreciated
    Its in tail servo setup,i think if you reverse the servo on setup,then reverse servo on transmitter,it should be correct.
    • Trex 700N RMJ,msh brain
    • Goblin 700 black thunder sport,vbar Neo
    • Trex 700L Dfc,vbar Night Flyer
    • Trex 700x,Vbar Neo
    • Goblin 570,msh brain
    • Goblin 380 kse,msh brain
    • ​NeXt sim and DX9 and Vcontrol
      Assuming you set up the Tx so that the Vstabi sliders move in the correct direction at the Transmitter setup stage that you must not reverse direction at the Tx. Just reverse the servo in the Vstabi tail setup screen.
        Thanks for the help. As I said I'd had to reverse the tail in the Tx as it was working the wrong way but then the direction was going the wrong way also. Didn't realise that reversing the servo in the vstabi software would reverse the sensor direction. All up and working fine now. Just waiting for a wind free day to field test
