80hv jive
  • 80hv jive
    is there any downsides to using a kontronic 80 hv on a 6s machine?,it is specced to run at 6s also so there should be no problems?
    SPY750 CLASSIFIED in build
    TBS DISCOVERY enroute
    Trex 450 pro in bits
    Nope, Jive 80Hv is from 16v so knock yourself out.
    What you got now??
      What you got now??
      thanks Ben,no not got anything YET!!haha,probably logo550sx as long as they are not too underpowered like their bigger brother,got a 80hv BNIB so was a case of sell it and get a 100v but if its not a problem id rather keep the hv one
        Vinny when you under powered what do you mean? bad pitch managment or you have the wrong setup mate.
        Watch from 2.25mins onwards
        Rotor Live 2013 | FSC R2 | Stu Smith - Logo 600 - YouTube
        Troll buster
          Originally posted by gashead View Post
          bad pitch managment
          you are quite right there ross,little private joke,you had to be there ...lol,deffo not underpowered haha
            Ah i see!!!
            Troll buster
              I'm going to use a 80 HV on my new 6s machine , however its approx 70grms heavier than a YGE90 Lv.
                a logo 550sx??
                  The recommended motor a 4025-1100 is a 100Amp motor. If you want a bullet proof setup then get the 100LV for a 6S setup.
                  If you never go stick banging and fly nice and smooth then the 80amps might be enough. Why take that chance though?
                  Member of Mk Heli Club
                    thanks Andy,i forgot about the amps,i think ive been down this road before
                      80hv jive
                      Hi Vinny
                      I promise you the 80 is more than fine. If you damage an 80 from over current then ill replace it with a 100.
                      Gareth
                        Thanks Gareth
                        have you maidened the sx yet?
                          Originally posted by Gareth-71 View Post
                          Hi Vinny
                          Gareth
                          You won't damage it as the controller will look after itself. The ESC could over-current shutdown or it could thermal shutdown; which is fine, you just auto the model down and then reset the ESC. With the oppotunity to fit a better suited ESC before the build begins then why not?
                            80hv jive
                            The 80 is perfectly suited!
                              Add a heatsink and it then becomes 160amp, 80hv is well enough, especially being Kontroniks.
                              Troll buster
