Kontronik Pyro 750 anyone??
  • Kontronik Pyro 750 anyone??
    Wont be long.
    No details yet but I got one coming soon for my speed TDR I have been told One thing we can safely bet is that no matter how powerful it is it will be a very efficient motor!!
    These pics are not mine as I got them of HF and its the first time I have seen the actual motor. Cant wait, hoping its an animal
    one of those would sit veery nicely in my g4
    Invertix 400
    Vortex 285
    TBS Discovery Endurance
    X4 II
    Schluter Champion Longranger
    G4 E720
    G4 E720 Big AIR edition
    Goblin Urukay super slow
    Goblin 700 KSE Slow
    Goblin 700 KSE Fast
    Srimok Faifa
    Spectra G
    Synergy 766
    http://mangled-rc.com/
      Few more pics courtesy of Olli
        Absolute class
        Cheers Matt
          What's the grey 'spiky' (?) thing in front of the motor ?
          Yes, it's th@ tw@ Scallyb@...
            Its a heatsink built in to the motor mount. I have one but a different style
              Would this be a more powerful/usable option than a 800-48?
              Got a 700-52 to got in my new Diabolo for now and was looking at squeezing a 800-48 in once I get the heli set up.
              Blade mCPX - now Version 2
                I dont know the specs.
                It could be inbetween the 2 or it could be an insane monster for the 700's and more powerful than the 800
                  Hi Jamin_00,
                  I see on the Kosmik that the yellow wire on the Slave output is not connected. Why is that? Should I do the same when connecting to a vbar?
                  Brian
                    I would have thought that the lead from the slave connection should be connected up - especially if you are using high current servos.
                    I'll be connecting mine up to my V Bar anyway, but I'm using MKS HV servos.
                      I'm going to be using MKS high voltage too. I hadn't thought about just connecting the 2 leads as supplied until I noticed in the picture above. I guess the yellow wire is signal only and shouldn't have any power.
                        Yellow is only signal so afaik it does not send anything only being hooked up to the slave so I guess maybe this was the only lead he had or just using that so not wasting another lead??
                        All mine I use on the slaves are the same as I use for the master so even have the ring on
                          From the Kosmik manual
                          'To provide full BEC power all KOSMIK ESCs feature two BEC connectors which have to be used obligatory when BEC current is more than 5A.'
                            Hi Malc1,
                            yes I understand that and will be using both leads but if you look at one of the pictures posted above you can see that the yellow wire is not used on the slave output... That was my question
                              And advisable to use a buffer still
