kontronik & goblin question/problem
  • kontronik & goblin question/problem
    On my goblin i'm running the pyro 520 motor with the standard pinion and 80hv kontronik esc, i maidened it today and to get the headspeed at 2190 at 55% throttle and 2100 @ 47%, this not what it should be, i'm running a 20t pinion onto the main gear, accoding to mr mels headspeed calc it shouls be not what i have, any ideas whats gone wrong, but boy does t fly nice even at these low throttle curves.
    Troll buster
    Is the gearing of the belt 1 to 1 if not you need to factor that in.
    Member of Mk Heli Club
      You kept that purchase quiet Ross! Can't wait to see it fly...You keeping the E7 now?
      Goblin 500 SK540 jive 100lv
      HD 500 SK540 jive 80 lv
      Oxy 3 SK540 minijazz20
        Have you calibrated your TX with the esc
        http://heli.dacsa.net/MrMelSite/styled-3/index.html
          [QUOTE=Johnda;825351]Have you calibrated your TX with the esc[/QUOTte
          When you say calibrated, i always reset the esc mode 1 then programme in mode 11, what do you mean calibrated?
          Troll buster
            Yeah still keeping the E7 Graham, goblin is a heli only it mother's could love.
            Troll buster
              Watch the vid Mr Mell explains who to match the throws on your throtttle stick the the esc, if you haven't done that then you will never get the HS correct
                When you calibrate, you set the endpoints.
                That 55 is more like 77'ish.
                MrMel has done a good vid on it, pretty much the same as setting up a Castle.
                x 3
                  so basically as long as i tach the headspeed, it will be fine?
                  Troll buster
                    Watch the Vid, skip to 5:40
                      You @ the club Sat ?
                        Yes, but the above values aren't 'true values', as it hasn't been calibrated.
                        x 3
                          Yeah mate you?
                          Troll buster
                            Originally posted by gashead View Post
                            Yeah mate you?
                            Yep, should be there for 1ish, see you there. Just make sure that goblin has a brown paper bag over its head, lol...
                              If your using spectrum Ross your throttle endpoints should be around 82% high and low once calibrated with an 80hv
                              Avant mostro 700E
                              Avant mostro 700 Nitro
                              member of :
                              South cheshire heliaddicts
