Set up a jive 80HV for mode 1 and 4 with linear 0-100 throttle curve in normal mode on 8fg. realised afterwards that the throttle trim was pulled down fully.
Does this make a difference? I tried to repeat the set up with the trim in the middle (so I get a true -100 to +100 on servo screen) but the jive wont arm unless the trim is all the way down.
If it is ok to run this way should the trim remain down for the idle up conditions also?
Dan
Dan
