Align 700 MX 510 kv
  • Align 700 MX 510 kv
    Has anyone got the timing & PWM info for this motor?
    Sent from my GT-I9505 using Tapatalk
    Logo 550SX VBar Neo
    T-Rex 600N DFC VBar
    Logo 690SX VBar Neo
    T-Rex G800 Helix Gasser VBar
    T-Rex HB7RC 800 HeliBug Gasser DFC VBar Neo
    5 degree timing and 12 khz PWM
    Goblin 500
    | Blade 130x | Blade 180cfx
    Spektrum DX8
    GWR Pilot 2011 & 2012
      ●Input voltage:12S
      ●Max continuous current:90A/150A(5sec)
      ●Max output power:4000W/6600W(5sec)
      ●KV value:510KV
      ●Stator Arms:12
      ●Magnet Poles:10
      ●Dimension: spindle Φ6xΦ52x57.5mm
      ●Weight: 405g (prox.)
      Collector of SAB Goblins
        and what danch said LOL
          If you're using a Castle Ice they recommend 8khz.
            I have tested 8khz and outrunner on castle 120hv2 on 700mx 530kv in goblin 700
            results
            8khz
            current 27-126amp
            watt 1208-5325
            temp 127-169 f
            rpm 1285-2275
            outrunner
            current 19-98 amp
            watt 867-4175
            temp 109-162f
            rpm 1035-2252
            Santander Factory Team
            Proud wearer of 5 x EGS
              Thanks guys. These are the numbers I was after.
              5 degs doesn't sound much ! though.
              Stuart
              Logo 550SX VBar Neo
              T-Rex 600N DFC VBar
              Logo 690SX VBar Neo
                results
                8khz
                current 27-126amp
                watt 1208-5325
                temp 127-169 f
                rpm 1285-2275
                outrunner
                current 19-98 amp
                watt 867-4175
                temp 109-162f
                rpm 1035-2252
                Gixerman are you sure about 8Khz?? Using a simple formula of the net its sound more like 12..?
                Its surprising that these details aren't widely published.
                Stuart
                Logo 550SX VBar Neo
                T-Rex 600N DFC VBar
                Logo 690SX VBar Neo
                  Stuart
                  These are my finding after testing the motor and esc combo, after getting different stories or info. Now you decide which way you want to go
                  brian
                    Thanks all, I'll try....
                    8Khz which will draw less Amps, though some do run on 12 KHz, . The 5 Degree is correct
                    Logo 550SX VBar Neo
                    T-Rex 600N DFC VBar
                    Logo 690SX VBar Neo
                      I cant change the PWM on my scorp esc, and Im using an Align 700mx 510kv at the minute, Very efficient motor!
