Hi All just got a Scorpion Next D 4525 520 the black one is any one using it ? I have a scorpion 130 sbec esc but cant find enough info if its man enough for the motor also any info on settings would be good I will be using the v bar govner Thanks Jason
Scorpion Next D 4525 520 help
iCharger 4010 , PL8 charger,
Vbar Control and a case of lithium plus an eu10i genny !!!Tags: None
I have a 4525 520 on my Goblin and use the 130 Scorpion ESC (No built in BEC I use a 2s lipo for receiver power). I don't have the governor set (may get round to it) but i have had no issues with the esc at all. I have the spool up set to V slow start and it is great. I have mounted the ESC directly against the mount on the Goblin and cable tied, it never gets warm (the motor does but that is normal)
Have fun you will love itLast edited by Kwickkwack; 23-08-2012, 08:17 PM.Rob
TDR (in progress)
SAB Goblin 700
Vibe 90SG Vibe 500E
Kalt Baron30
Thanks for the reply The esc does not fit flat on the place with the caps on the end may need a spaces making of somthing that conducts heat ?Goblin 700 comp 3 blade Kyle stacey head and tail, 160 scorpion esc , ultimate motor,MKS. Vbar NEO
