OK, for those of you familiar with the dark art of electricity and the mysteries of all that stuff to do with efficiency and amp draws under loads etc...
On any particular heli you will have an average amount of power required to hover and fly around and what it takes for a given headspeed and you'll have a certain max power draw under full pitch etc.
So what I'm curious about is this; You could have a motor that is just capable of handling all the requirements of a given heli. As if it was a .50 engine in a 50 size heli for example.
Or you could easily have a much bigger motor that is going to be spending most of its time working much less than it is capable of, say the equivalent of a .60 or .90 engine, although it is capable of much greater current draw it will never be loaded enough to produce max power or draw it's max current, it will never bog.
So between the two scenarios, is it possible that the smaller motor might actually draw bigger peaks if it is loaded heavily in relation to its max power rating? In other words is it possible to have a bigger motor actually draw less power because it is never having to work very hard, never bogged?
Will the bigger motor draw more current just in a hover simply because it's a bigger motor?
(for the purposes of this question lets ignore the weight of the motors and assume the ESC and Lipo have enough headroom for either one)
and a platinum star
As I say, that's knowledge held by the dark side of the force
