Recently got a pl8 and para board and its fine with my align lipos but my old faithful Kokam SLPBs have the skinny type balance plug and won't fit the board. Can I replace the balance plugs with the type that do fit? Is it just a simple solder job just making sure the leads go in the same order ? Or a no no ?ImageUploadedByTapatalk1367788440.595360.jpg
Balance plugs
It should be fine as long as you do it in the right order one at a time. I never change type but replaced the old with new one. One lead at a time and insulate it then the next one till you done.Compass 7HV, Beastx
T-rex 600 EFL Pro, BeastX.
ElyQ 50 Comp XE, BeastX.
T-rex 450 Pro DFC, MSH Brain.
Blade 130X stock.
550 quad, Multiwii fc.
Aurora9, DX6i, 6EX, FF8.
You can replace the balance plugs,
but as Franky said mind those wires...
had similar situation with some Hyperions, and an "safer" option is to leave the lipos balance plugs alone, get some standard JST and kokam leads (try GS) and do the soldering with these,
leave the conversion lead in the paraboard and use it to charge the kokams.
Changing the balance lead is a good option in the sense that you can check the lipos charge status on the field with those common battery checkers, so I would't dismiss that option.
keep a bucket full of water around. (you may get thirsty)
As far as i know the lithium fire split the water (H2O) into hydrogen and oxygen so i would leave that option alone. If you have a fire extinguisher for cat D (Live electrical) handy that's fine.Originally posted by Peper View Post.
Compass 7HV, Beastx
Blade 130X stock.
Yep, agree with that, surely a fire extinguisher would be the best solution...
Tough I must confess, I have submerged a few lipos (water planes and RC boats
) and never experienced any problem.
Originally posted by Peper View PostYep, agree with that, surely a fire extinguisher would be the best solution...
Yes they are fine with water-until they caught fire...
Compass 7HV, Beastx
Blade 130X stock.
