PL8 charge problem??
  • PL8 charge problem??
    Guys I am having a problem with my PL8.
    I cannot charge my 2s lipos to 100%. At 91% it says lipo charged. I tried on every setting I can thin off with not luck.
    Can anyone tell me what I am doing wrong please!
    sigpic X 2
    Are you using USB lead or program on unit?
    Santander Factory Team
    Proud wearer of 5 x EGS
      Brian no mate. I am charging with the pre programed slots.
      Accurate charge.
      sigpic X 2
        Press the inc and dec button together, to go in settings make sure 4.2v and not set for cold weather charge could be problem, is battery defo perfect
          Cold weather point set to 10c! The charger is in the garage and it's cold. Should I change that?
          sigpic X 2
            It's cold out, that setting is there for a reason.
            Bring it all inside and let the packs warm up for an hour and then charge to 4.2v
            You can turn it off by going into settings mode as in the manual .
            Joe
            Invertix 400
            Vortex 285
            TBS Discovery Endurance
            X4 II
            Schluter Champion Longranger
            G4 E720
            G4 E720 Big AIR edition
            Goblin Urukay super slow
            Goblin 700 KSE Slow
            Goblin 700 KSE Fast
            Srimok Faifa
            Spectra G
            Synergy 766
            http://mangled-rc.com/
              As above cold weather setting, as Joe says bring them inside and let them warm up a tad. However, don't then put them back outside in the garage as they can over volt. Leave them inside or take the cold weather charge and reduce your flight time to compensate
                Thanks guys.
                Inside now getting them warmer, so Il try again!
                Bring on the summer!!!!!
                sigpic X 2
                  Thanks one's more guys!
                  That worked perfect!
                  Clever that PL8 innit?
                  sigpic X 2
