PL8+MPA+6 Lead Y Harness
  • PL8+MPA+6 Lead Y Harness
    I'm getting confused on what I need to have to charge my 6 130x lipos at the same time. I was hoping to use my MPA board connect the y harness with the 6 lipos to the board via XH then connect the two banana plugs to the pl8 will this work? Oh and my lipos only have a balance lead
    That should work fine - is there a problem?
    | 3D Championship
      As the 130X uses 2S packs isn't the PL8 going to complain about the lack of discharge wires connected to the MPA board?
      If the harness has discharge wires as well then I expect it will work OK.
        This is why im doubting myself. It should work as the harness as two banana leads which will go straight to the pl8. Then I only connect the MPA board to the PL8 via the balance lead. Then the other XH connector on the harness to the board also. The y-harness should arrive today.
          That should be fine, as long as you have the discharge wires connected as well as the XH then it should just see it as a 2S pack with 6 x the capacity of a single cell.
          You'll want all the packs to be the same of course but aside from that I can't see a problem.
