Hi All
I am just using my PL6 for the first time. I have this connected to an MPA board using the MPA-FRC adapter cable. I have the PL6 set to charge XH batteries.
I have successfully charged through this set up a Turnigy 2200 2 cell battery where it correctly idenitified and measured the 2 cells as they charged.
I have now come to parallel charge my two main Turnigy 3300 6 cell batteries and I am getting an error code - 'Bad Cell Count, Node Wiring XH'. I have tried charging one at a time, tried using different ports etc. and still get the same message. I have depowered and repowered the unit etc. Having a look around the forums the next step seems to be using a digital volt meter to check the output on (I think) the output from the adapter cable coming from the charger (into MPA), the output on each of the balancing ports on the MPA, and the output on each of the balancing port elements of the battery, to see what voltage they are reading.
As I don't have a DVM (Although I probably should get one anyway!) is there anything else I am missing before I go down this route? Would it be worth buying a straight Adapter Board (JST-XH PL8GPKOSTD) for £7 and plugging this straight into the PL6 and seeing if it will charge a single battery then?
I have very little electronics knowledge so any help gratefully appreciated but please keep it basic! TRying to learn as I go.
many thanks
Dave
many thanks
Dave
, 130x, nano cpx
sold
