I purchased my MPA board brand new from fast lads at AIR/weston park earlier this year, when purchased it only came wrapped in bubblewrap and no instructions. Which just being a charging board I thought was fine.
But I've been looking at my LiPo IR levels more just lately and noticed that cell 6 is always higher than the other cells, on all my lipos!
The reason for this is because of the "wiring mode" inside the PL8.
If you are using an MPA board you must set it to use JST-XH Node wiring NOT FMA mode. This is mentioned in these instructions here: http://revolectrix.com/support_docs/item_1401.pdf BUT obviously if your MPA board didn't come with such instructions then you may be running it in the wrong mode like me.
So just thought i'd point that out since theres been a lot of discussion on LiPos and Cell IR's just lately.
If you're using the parallel safe boards then you leave it in FMA mode even though the boards have JST sockets on them, this apparently is because the boards are wired to convert to FMA. Whereas the MPA board is a native JST-XH and so the wiring mode in the settings needs to be changed.
Matt
Matt
. Porscheboy on
