How to
  • How to
    Can someone tell me how to balance charge this battery please as it doesn't have my usual balance connectors.
    Buy a thunder power balance board for your charger.
    Invertix 400
    Vortex 285
    TBS Discovery Endurance
    X4 II
    Schluter Champion Longranger
    G4 E720
    G4 E720 Big AIR edition
    Goblin Urukay super slow
    Goblin 700 KSE Slow
    Goblin 700 KSE Fast
    Srimok Faifa
    Spectra G
    Synergy 766
    http://mangled-rc.com/
      Easier finding hens teeth since you need to plug a 3s and 5s in together. Ask me how I know.
      What charger are you using? I have a PL8 and made my own balance lead for 8s thunder power packs. They balance on a 5s and 3s plug together. I no longer use the packs so will send you the lead. Alternatively if your charger is a different one I can pm you instructions how to make one.
      I have two tools in my tool box. A hammer...... and a condom. If that doesn't work then it's TJFGOP.... The Jobs Fd Going On The P:::::::
        This one does Thunder power and jst xh.Balance Board – TP & JST XH « ElectriFlyer
        The Fleet
        Trex 450 Pro on Brain 2
        Mini Titan super Cobra ah1
        Alien 550 Quad.3DR Pixhawk
        Futaba 7C 8FGS 14SG
        Specktrum DX6i
          It wont work. It's designed for single pack balancing. You need to be able to plug a 3s and 5s in at the same time. It will fry the pins.
          Hence me making my own
            It's a 6s thunder power connector. The same ones fitted to my thunderpower packs and the same as the ones fitted to my flight powers I used before.
            Invertix 400
            Vortex 285
            X4 II
            G4 E720
            Goblin 700 KSE Slow
            Goblin 700 KSE Fast
            Srimok Faifa
            Spectra G
            Synergy 766
              Then it will work if the board has two 3s inputs. Im just looking on my phone and the pic looks like my old 8s packs. So apologies if my eyes deceived me.
                The reason I thought it would be ok is that if you look at the board it indicates that for 6s you use both sets of pins. 3pin and 5 pin. Is that what you are saying should or shouldn't be required. I haven't used TP connectors so I don't quite follow the issue.
                The Fleet
                Futaba 7C 8FGS 14SG
                Specktrum DX6i
                  Its the way they crossover. If the board is labelled and it shows the 5 s and 3s to be used together then it should be ok. But trust me, soon know if not. I blew three up with an 8 s pack on a 5 and 3 plug before I discovered what was wrong and made my own lead. Either way, its cheap to try, the board just goes pop. And then you have the bits you need if your making a lead up. Lol
                    Thanks RafeyRJX.
                    I'll be sticking to jstxh.thats for sure.
                    The Fleet
                    Futaba 7C 8FGS 14SG
                    Specktrum DX6i
                      You do need ensure you get the 3s and 5s connectors into the right sockets. I've blown a board up crossing that over myself.
                      Invertix 400
                      Vortex 285
                      X4 II
                      G4 E720
                      Goblin 700 KSE Slow
                      Goblin 700 KSE Fast
                      Srimok Faifa
                      Spectra G
                      Synergy 766
                        Well now, I am well confused.
                        @ RafeyRJX I have a 4 button type charger. Thanks for the offer. PM on the way.
                        I'd rather flog the heli than start messing with batteries.
