Cellpro 10s parallel charging 6s 3000+ what charge board?
  • Cellpro 10s parallel charging 6s 3000+ what charge board?
    Im just looking to charge maybe up to 4 lipos at once on my 10s just wondered if this is the correct board to do it with?Parallel Charger Adaptor Board for XH Battery - EC5 | Midland Helicopters Ltd Not sure how it all plugs in either, I understand that the cellpro 10s is about 220watts output at 12v, my psu is rated at 12v 400w 30amps, so the psu is up to it the 10s im guessing will just take a little longer to charge the 4 lipos at around 300watts, as it will limit itself to its maximum output?
    Does this board just plug into the 6s bit on the cellpro 10s balance board?
    Thanks in advance
    Sab Goblin 500
    Yes that board will work fine.
    The 4 lipos will appear as one large capacity lipo to the charger. 4x3000mah 6s lipos in parallel will be equivalent to a single 12000mah 6s lipo for example. If you normally do an auto 1c charge then the cellpro will charge at its maximum 10A rate, give or take a bit. Its all fully automatic and quite idiot proof.
    Yes, it plugs in the same way as a 6s lipo.
