Cellpro 10xp charge control software question
  • Cellpro 10xp charge control software question
    Hi,
    I have the usb cable for the Cellpro 10XP and have downloaded the charge control software. All is good and have used it all to good effect. Except one setting I'm not sure about and can't find the answer to.
    On the presets tab, there is a column at the end called Fuel Table. In the drop down box it has 15c, 25c, 40c etc. Do I need to set this to the C rating of the lipo's I'm charging or does it refer to something else?
    Also if it is the C rating of the battery what happens when I charge multi batteries with different C ratings. For example my Align receiver packs are all 2s, 1900mah but 4 of them are 40c and a couple of them are the older 18c ones. Do I set it to the higher C rating in the drop down box or the lower C rating?
    Thanks for any help. Hope I've explained that right
    Cheers, Rich
    SWRCH - Go Big or Go Home
    Just a quick bump on this one to see if anyone knows the answer. Thanks
    Cheers, Rich
