Another help thread for my cellpro 10s
  • Another help thread for my cellpro 10s
    Hi,
    I have my cellpro 10s now setup with a parallel board and can charge 6 x 3s lipos no probs. I am now using xt60 connectors on all my 3s lipos and my parallel board has xt60 discharge connectors and jst-xh balance connectors.
    I also have 5 2s align receiver packs all with the standard red plugs (jst I think they're called) and the jst xh balance connectors. I can plug all these lipos onto the parallel board via just the balance plugs but the charge rate is restricted to 4 amps for the lot so will take ages to charge them all. I can't find a parallel board that has the red jst plugs on it so I can plug in both lipo leads and charge them all at 1c like I do with my 3s setup.
    Anyone know of a board or leads that can do this job or should I chop all the red plugs off and put xt60's on all my 2s packs? My concern with swapping the plugs is that the discharge wires on the 2s packs are very thin for the xt60's?
    Thanks for any help.
    Cheers, Rich
    SWRCH - Go Big or Go Home
    Put xt 60's on em mate just make sure you use a good quality heatshrink to help strengthen the thin wire to the packs.
    You could also put double heatshrink on i.e some 2mm to strengthen the wire & some 4mm to shrink down onto xt60 terminals.
    Martin
    Aka RCSlopesurfer
