I have fitted a Align 35A Brushless ESC(Governer Mode) RCE-BL35P HES35P01 ESC to my 450, I have set it per the instruction.
The soft start seems to work when I first raise the throttle, but if I drop the throttle to the mid stick and then increase it the motor does not immediately increase it seems to be so soft starting again is this normal?
I thought soft start was only used when the throttle was at increased from the lowest stick position but once it is running the throttle response should be immediate with the stick change, is this not the case?
I havent actually flown this yet only tested on the desk, will this be alright when I do/
Have I set something wrong or need to do something else?
The throttle curve is a straight line 0 to 100.
Any help greatly appreciated.
